Posted by pete 23 on February 18, 2011 at 16:11:34 from (173.87.146.142):
In Reply to: gen and reg question posted by bob-b on February 18, 2011 at 10:43:22:
You need to check voltage while it is charging. If 6 volt system anything above 7.5 volts would be high and on 12 volt system anything over 14.8 would be high and require regulator repair or replacement. If voltage is lower than that and still charging high rate you have defective or very dead battery. If voltage it low and battery is gassing heavily you have bad battery. Of course a good battery will gas heavily if voltage is too high.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
