Are the bolt holes still in good shape,if so, best puller I ever had was a heavy piece of metal, like 5/8th inch thick, just long enough to fit in depression of wheel. Drill two holes to match holes in steering wheel. Thread bolts into steering wheel until they bottom out, than gauge how many washers it takes to give you just about one thickness of washer of tension. Then reinstall both bolts, don't over tighten so as to strip threads but tighten them down good, give her a rap right in center over shaft with hammer and punch. Lots of penetrating oil, and if and when it comes loose you may have to remove bolts and add more washers. Nut on end of shaft to protect threads also.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
