Can a '41 distillate H pull a fully loaded haywagon in 5th?
Posted by Yooper Farmall on February 22, 2011 at 13:14:46 from (141.210.112.16):
After rebuilding my "41 H I was surprised it didn"t seem to have more power. It seemed to struggle taking off in 5 gear and worked harder than I thought going up hills in road gear.
Then I remembered growing up the H I drove was usually only in 4th gear, and it was a 300 that I"d haul fully loaded haywagons back and forth between farms. Is a 300 that much more powerful than an H? Are they geared the same?
My H has a low compression distillate head recently rebuilt, and I replaced the pistons with high compression pistons.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
