jackup your tractor on the bad side and rotate the wheel by hand, sounds like your rim is not properly centered. also you may stick a crowbar under it and lift a bit if your bearing is looseyou might be able to get some movment upand down on the axle bearing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
