That depends on what coil you have . Did the previous owner replace the(1.5 ohm) 6V coil with one with a (3 ohm) 12V primary winding when he converted to 12V ?
If not, you need to replace the 6V coil with a 12V model or add an ignition ballast resistor in the wire between the ignition switch and coil primary terminal.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
