Re: ih 140 plow
Posted by mazemeister on March 04, 2011 at 19:23:39 from (24.188.81.230):
In Reply to: ih 140 plow posted by gaston ruiz on March 04, 2011 at 18:25:52:
depends... the 140 was available in 3 or 4 bottom, and i believe 16" or 18" bottoms. my experience is with a 4X16 and that is a good load for a 986. when pulling a clodbuster, we used a green 4630 and that was also a pretty good match. both cases plowing around 5 mph.
(for bystanders: the 140 is a rollover plow)
around these parts an 806 was considered a 4-plow tractor and a 706, a 3-plow tractor
so... if your soils are anything like here, you"re good to go with a 3 bottom; if it"s a 4, you can probably do it, just slower, maybe not as deep. either way, put all the weight you can on the front end. with 1200# on the 986, it"s still easy for the front to come up on ya
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
