If your bolster attachment points are 5/8" use 5/8" all thread. Sand then clean with solvent, the snout and inside the pulley before putting it on (especially if it was bad getting it off) The pulley should be a tight press fit, but not deadly tight. I had one in a 60 ton press (crank, pulley and front cover) and used 20 ton of that force to get it off. Make sure it goes in all the way, When placing the seal, try to place it so that it runs on a new non-grooved location on the pulley. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
