Posted by pete 23 on March 13, 2011 at 10:52:33 from (173.87.146.142):
In Reply to: F460 Hydraulic Noise posted by SteveF460 on March 13, 2011 at 05:39:04:
Did your orfice screen have a check ball in it or did it have one previously. If it did there will be a hole for a roll pin to hold ball in place. What happens with those is the check ball bounces back and forth and closes the orfice hole too small. It should be .031 when new. I drill them out a little to make up for leakage agcross the regulator valve land in the hydraulic valves. So , depending on what you have for an orfice will determine your course of action. It is a trial and error to get the correct size, too small it will go on demand intermitently or constant when warmed up good, too large a hole and it will not go on demand. .040 would be a starting point. If it quiets down when on demand you are most likely ok with the filter and or sucking air situation.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
