Posted by Wardner on March 18, 2011 at 12:23:46 from (209.86.226.60):
In Reply to: MD tranny teardown posted by BruceS. on March 18, 2011 at 10:56:43:
I may not know what I am talking about as I have never done the job. I always thought the input shaft w/constant mesh gear and belt pulley gear could come out without removing the rear frame cover. You have to remove the Liftall and clutch shaft and unbolt the transmission input bearing retainer. The input shaft and bearing should slide out and escape the tractor where the Liftall used to be.
After all, this is how it disassembles should the tractor be split at the transmission. With the Liftall out, there is plenty of room.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
