H firing problem
Posted by pintobill on March 26, 2011 at 15:22:12 from (174.253.135.181):
I had another post on here a couple of days ago about my H
that would not start. It was acting like it was way out of time.
I have it running now. When the engine is cool it runs fine,
but when it warms up it starts missing. I pulled the distributor
cap off and one side of the plastic part of the rotor was
melted. I looked inside the cap and three of the prongs had
black streacks running from them going back to the rotor. I
changed the cap and rotor, when I started it back up it done
the same thing it done fine at first then started missing again
with the same results to the new cap and rotor. What would
be causing this. The distributor has new points and condensor
that I just put in. I am also running a MSD box on this tractor
because it is only used for pulling. Thanks for any help
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
