No problem to use high side only except for you shifting out of gear problem. What I would do is take a look at the TA drive clutch through that top little four bolt cover and see if it is all intact. If it is you could just put the short linkage between TA clutch and main clutch and adjust it so TA clutch releases when pushing in main clutch. If some internal parts have been removed or clutch or planeterys welded or bolted solid you won't be able to do anything except major repair. I should say, utility may present problems getting at that cover, row crops are easy, not sure.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
