Posted by Janicholson on March 30, 2011 at 15:02:11 from (67.72.98.45):
In Reply to: Clutch or TA slipping posted by The West-ridge farm on March 30, 2011 at 14:06:26:
The low pressure symptom in the steering is also a TA factor. The direct clutch in the TA id hydraulically applied. If it gets low presure, it will slip, and since the TA rear clutch (sprague) and rear locking clutch Hydraulic are needed to have the TA work, and it does not, The issue is what to fix. If it were mine, I would repair the TA and put a new Control pump in it. The MCV pressure needs to be checked first. The pressure control valve could be causing the slipping in direct. Best of luck. JIm
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
