Re: thrust bearing on h
Posted by Janicholson on April 01, 2011 at 10:22:26 from (199.17.6.112):
In Reply to: thrust bearing on h posted by jb-h on April 01, 2011 at 06:58:49:
A direct replacement may not be available. I would work with a bearing (good) supplier to find a close heavy duty replacement, then shim, or machine an adapter to make it operate. Just me though. Someone may find a OEM answer. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
