Re: Super C Starter Drive grinding need advice
Posted by gene bender on April 05, 2011 at 03:32:21 from (67.55.227.7):
In Reply to: Super C Starter Drive grinding need advice posted by Don's Superc on April 04, 2011 at 22:09:36:
Bend the tabs that lock the set screws and they will turn out letting the Bendiz slide off the shaft. Keep tract of the washers used on the armature shaft. Easy fix. There will be a core charge on the old Bendix so take it along.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
