Posted by Ludwig on April 14, 2011 at 16:25:22 from (69.87.193.179):
In Reply to: Re: 140 6 to 12 volt posted by janicholson on April 14, 2011 at 11:29:11:
"If was 12volt to begin with it was probably positive ground (even if it was 6 volt, it was positive ground) the VR closes instantly and is a short to ground when hooked up backwards."
I don't think thats true. Our '52 Super M got run with the 8v battery in backwards (negative ground) for YEARS and other than the fact it wouldn't charge it didn't seem to hurt anything. I finally realized the problem, turned the battery around and it suddenly started charging...
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
