Posted by JWCarp on April 21, 2011 at 19:30:18 from (67.142.163.26):
I am trying out a 1256. The only thing I can find wrong is a couple of fuel leaks on the injection pump. One is on the injector line for #6 cylinder. I took it loose from the pump and put in new gaskets, and it still leaked. It appears that connections is worn on one side, which could be causing the leak. The other leak is in the bottom middle of the pump wher there is a plug on the engine block side and a cap on the side facing out. Does this sound like something expensive to fix or fairly simple for me or a pump shop to fix. I assume that I will need to get a new line for #6 cylinder to fix that leak. Any help will be appreciated.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
