Posted by Janicholson on April 24, 2011 at 17:08:21 from (67.72.98.45):
In Reply to: IH 560 not charging posted by Bill Poust on April 24, 2011 at 16:44:12:
A Delco 10SI has three connections. (easy fix) One is the primary charging wire #10 gauge it goes to the battery at the starter solenoid on the starter, or to the amp gauge if it has one. (I prefer to have it connect to the battery through a fuse link. This is a short special wire that is a fuse to protect the system. It should be rated at 5 amps over alternator output.) The #2 spade connection on the edge should have a short wire connected directly to the big main output discussed above. (6" of #12gauge wire) The #1 terminal is connected to the idiot light. The other terminal of the idiot light is connected to the ignition switch terminal that connects to the coil (or ballast resistor). A diode (3 amp 150piv) can be used instead of the idiot light (band end of the diode toward the alternator). Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
