Re: Return line on belly pump system
Posted by ljs01 on April 29, 2011 at 03:31:59 from (67.224.21.106):
In Reply to: Re: Return line on belly pump system posted by David G on April 28, 2011 at 19:54:52:
If you put the return on the top, wouldn't it just suck air after it emptied the first time? Maybe the place to go is the drain plug at the bottom?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
