Ours was full of fluid too w/sludge at the bottom. If you removed the plug does that mean little or no fluid will be pumped into the reservoir when using hydraulics. Maybe leaving the plug loose so the condensation will drip out would work. That's what we are doing w/the main drain plug under the draw bar but only when tractor is not in use. The tractor has a loader so it's tough to get the water out of the system short of a flush & taking the hoses off & blowing air through them. We haven't put the cover back yet because it needs a new gasket & we broke 3 bolts taking it off so they have to be drilled & tapped. Guess that was the first time it was removed. Our old 800 case never gets moisture in the hydraulic system. That's the worst thing about our 656. Thanks for your reply bc.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
