Posted by ericy on May 06, 2011 at 10:28:01 from (205.188.116.73):
The ole H is in need of new bushings in 5th gear it has the death woble so I found a complete top bolster that came off a tractor that had a wide-front end most of its days it seams good and thight. My question is ..... can i safely block up the tractor say around under the bell houseing-belly pump and remove the hood,stering shaft,nose sheet metal,drain and remove the rad, lower bolster, Then try to remove the upper bolster with out the engine falling in the fram fails or looseing them???? I know the upper bolster is heavy I can use my "cherry picker" to lift it ok just wanted to know how you all would do it Thanks
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
