Re: Help with Farmall H after electronic ignition install
Posted by Solid Labor on May 08, 2011 at 17:23:27 from (166.205.14.72):
In Reply to: Help with Farmall H after electronic ignition install posted by Stevishere on May 08, 2011 at 17:00:25:
Your timing at 750 RPM's should be around 7 degs. and 1850 RPM's around 30 degs.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
