Remove the gearshift lever and center all three shift forks.
The nub on the gearshift is worn and slipped out of the fork during a shift. It's now stuck in one gear or another, and every time you shift it, you put it into two gears at once.
It's a common problem with old tractors. You need to be more careful and deliberate with your shifting for now. The real fix is to build up the nub with weld and grind it down to its original size and shape.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
