Posted by notjustair on May 14, 2011 at 19:26:17 from (70.252.150.124):
Just bought a '50 M. Runs very nice. Uses a bit of oil, but has sat for a long time, so it may loosen up.
PO changed it over to 12 volt. I prefer original, but it is well done and not sloppy. He put in a 12 volt coil (which I hear isn't the best option). Here is my dumb question: would it still use the original style points/condenser? The coil should put out the same juice to the distributor regardless of whether it is 6 on 6 volt, 12 or 6 with a resistor on a 12 volt, right? This is my first engine of any type that has been converted from 6 to 12.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
