Posted by steelfronts on May 22, 2011 at 18:52:40 from (75.134.112.136):
In Reply to: 113-123-135 engine ID posted by the Unforgiven on May 22, 2011 at 17:12:24:
The 113 most likely wouldnt have a water pump. The 135 and 153 quite often are marked on the block C135 or C153. The 153 blocks are a litttle longerso there is a little shelf in front where the head meets. The bigger engines may have dipsticks and not be cut out for the steering shaft like on a B fqrmall. The 135 and 153 would have a hole blocked with a plate where the hydraulic pump would go on the tractor engine.I have put all of them in C"s and B"s. You are right they almost fit
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
