You have a starter built out of mismatched parts. The 1107448 starter is used on Farmall H and M series tractors. It had a two bolt mount on the drive end. Most likely the housing has had two holes added for mounting the magnetic starter switch to make it work in your application.
The two bolt mounting drive end frame has larger holes than the three bolt housing. I have never tried to install one in a three bolt clutch housing so I don't know if you could make it work or not. The drive end frame that you need to replace your broken one is 1931507 (delcoRemy). It was discontinued back in the 70's so you are unlikely to fine a new one from DelcoRemy. I have not found any after market source for them either though I suspect that that they maybe are being made in China as a lot of starters for older tractors are available as DR clones. DR parts will mostly interchange but the bolts in them are metric.
The correct number starter for you tractor would be 1108041, 6 volt system. The starter for a 12 volt application would be number 1108174. You could use either one on your tractor. Using the 6 volt starter will be a little harder on the starter drive as it will kick in faster than the 12 volt but they usually last a long time anyway. The 6 volt magnetic switch will also work on 12 volts but it will have a shortened life if held engaged for too long at a time.
This site lists a starter for the 6 volt systems. There is a $60 core charge added that I would expect you to lose a good share of with your broken housing. You may want to ask what the reduction in core credit will be with a broken housing when you are looking for a starter.
This post was edited by Owen Aaland at 21:45:59 05/27/11.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
