Remove the spring and linkage components from the lever. Use a Oxy-acetylene torch to heat the housing where the shaft comes out. (Heat only n the housing/bushing, not the shaft.) let it cool. Put penetrating oil on it PB Blaster, or Other juice. Take a large adjustable wrench and move the lever Cw, then CCW repeatedly and see if you can get it to budge. Repeat the heat step and cooling until it does. The worst is to loose the tin cover, which is not uncommon, and not terribly expensive. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
