Posted by andy r on June 03, 2011 at 21:51:10 from (69.66.71.73):
I need to adjust the rear wheel width on an International tractor with wedge lock wheel hubs/axles. I do have the outside wedges on both wheels loose. Did this by soaking with penetrating oil and backing the bolt out using a cheater bar. Eventually the outer wedges came. I do not have the "horseshoe" tool from the factory. What are some ways to get the inner wedge loose? The bolts will come out and I can remove the outer wedge. Can I put a good size shaft in there after I remove the outer wedge and hammer on it with a sledge??? Any ideas will help. Thanks.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
