If it runs off the engine it will be mounted to the back of the timing cover at the base of the distributor, I believe. If it is a belly pump it is a big heavy chunk of cast iron inside the clutch housing with three pipes sticking out, two to the left and one to the right, plus a fill cap on the top. This cap is sort of mushroom shaped and on the right hand side, as seen from the seat. I do not know where you fill the live pump system, however it does use its own separate oil, as the engine needs its oil for lubrication. Zach
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
