Re: Farmall Super C Starting Issues
Posted by oldiron29 on June 21, 2011 at 18:02:13 from (69.112.87.249):
In Reply to: Farmall Super C Starting Issues posted by Paul in CT on June 21, 2011 at 17:26:09:
Paul, How is the compression? Did you test it?
Or I would say your carb is pluged! oldiron29
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
