PTO RPM is 540, but that is at rated PTO maximum power, not Maximum engine speed (which is High Idle) The PTO will turn 580 to 600 at high Idle. The equipment will not care one whit between 540 and 600, so don't be concerned on that account. If the hand lever linkage moves the governor control lever to its full travel, (and it should) the governor will need to be either adjusted, or the main spring replaced (I recommend a new IH spring). Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
