Posted by pete 23 on June 24, 2011 at 10:09:23 from (74.32.230.16):
In Reply to: 656 clutch pedal play posted by Yellott Canby on June 24, 2011 at 09:04:42:
You can have a machine shop install a bushing. The pedal has such a large slot where it pivots on the shaft that you don't have a lot of surface so I have them put a bushing in and just put a hole for the grease fitting and then you will be on a lot of unworn surface on the shaft. The thing about that shaft is you cannot pull it out as it has a slot in it for the ring gear so you would have to take the differential out to get shaft out.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
