mike paulson said: (quoted from post at 11:27:20 06/25/11) just wanna clarify i'm not talking about lead length but extension cord lenght,..
i do have the correct line cord rated for the welders electrical draw, just wanna know what some of you guy's have.
and am i going about this the right way, should i be extending my leads instead of my extension cord? and if i do make a second extension cord is it ok to have a 30 and a 40ft plugged into each other or must it be a strait run? thanks for any info. i'm looking for about 70ft.
I think John T is telling you right.
I think it would be cheaper to extend the power cord than the welder leads. every foot of wire has a little resistance... the bigger the wire the less resistance. the longer the wire the more resistance. the more current across a resistance the more power is wasted as heat... the heat is not good for the insulation on the wires and any power wasted in the wires is not used for welding... what you're paying for it for.
I think number 6 is what you want for 70 feet at 2% voltage drop you could probably get away with number 8 if you really wanted to.
This post was edited by realolman at 12:31:05 06/25/11.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
