You need a priority valve. It uses constant output of the pump (main lever locked back) and diverts the required pressure to the steering torque motor. It is not---not-- the entire output from the pump. the other pressure port must be blocked off. Ports from the priority valve "drain" are directed to other uses, like a two way valve. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
