I'm in the Rusty camp, its more critical using a Magneto Ignition versus a battery powered coil distributor that the plugs and wires be NON RESISTIVE. The non resistive (plugs n wires) is a better impedance match up for a limited energy Magneto then the more forgiving higher energy battery powered ignition. An Autolite 386 or hotter 388 is in the correct heat range but they are resistive I believe while the similar heat range 3116 is not.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
