Re: priming w450
Posted by sflem849 on July 20, 2011 at 13:30:29 from (69.197.84.78):
In Reply to: priming w450 posted by dusty britches on July 19, 2011 at 20:54:24:
On my MD I bleed the Aux filter with the tractor off and the Fin filter with it running. I would assume that tractor is the same. (same engine, but newer)
You usually have to give them a little throttle while running on gas to bleed the injectors.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
