Posted by rustyfarmall on July 27, 2011 at 05:29:35 from (216.248.71.224):
In Reply to: steering gear on H posted by DannieG on July 26, 2011 at 18:55:15:
There is no adjustment on the half gear. If it is worn out you need to replace it. Otherwise, the only adjustments that can be made are to make sure the big pipe plug at the front is tightened securely and is putting a pre-load on the bearing. You may need a new bearing and/or a new pipe plug. Both are readily available.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
