I would remove enough of the side hood to observe the light switch and wires in that area. If you have a short it will blow the fuse. If you have poor connections they will get hot and smoke. But, also, if the dimmer coil is wet or oily,( maybe someone washed tractor in that area) it will smoke until it dries itself off. This often happens when working on a tractor or a new tractor. The dimmer coil should only be energized in the dim position but it may be wired incorrectly. Personally, when I convert to 12 volts I eliminate the dimmer coil
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
