Posted by Dennis Moeller on July 29, 2011 at 21:28:42 from (70.112.90.201):
I am wanting to replace the straight pin that mounts the power steering cylinder rod end to the front axle on my 966 International. I want to replace it with the later model taper type pin. This requires the hole in the axle where the power steering end mounts to be reamed or drilled with the proper taper to accept the taper pin. Does anyone have one of these taper drills that I could buy or rent or know where I might find one. I understand International dealers used them quite a bit when these tractors were newer, but I can't seem to find one now. It appears to be about a 3 1/2 degree taper. Thanks for your help.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
