Posted by RTR on August 01, 2011 at 16:20:48 from (74.248.177.224):
I have a '57 Farmall 130 that I can get any spark at the coil. I have hooked everything up as follows in the diagram, and it is key start so when I am turning over the engine it should be firing the way I have the coil wire hooked directly to the battery.
At the places where I drew a "lightning bolt" I have juice(checked with test light). The only place I can not get juice is at the end of the coil wire where it hooks to distributor. I've checked it against a good ground on the tractor.
I have replaced the coil with 3 different ones. Two of them off of previously running shed kept tractors (within the last 3 months). I have also tried another condensor and other coil wires. I filed the points with an emory board and they actually look fairly new.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
