Posted by pete 23 on August 02, 2011 at 19:35:02 from (74.32.234.149):
In Reply to: MCV Valve Issues posted by farmall706 on August 01, 2011 at 16:06:32:
In that case I would make sure the brake valve is not using excess oil. Just plug it off and recheck pressures. If that is ok you are looking at digging pulling mcv and doing some checking for blown gaskets, o-rings, leaking sump check, stuck regulator valve. In other words, I can't tell from here, only give you ideas.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
