Posted by tractorsam on August 07, 2011 at 15:49:45 from (24.222.60.206):
In Reply to: follow-up question: posted by Chris in WNC on August 07, 2011 at 15:15:59:
Towards the front on the left hand side of the transmission case (usually almost behind the brake linkage) there is a small pipe plug. After you've drained the transmission refill to this plug with 80w-90 gear oil. The oil from the transmission does not mix with the final drives. If you have a belt pulley or PTO you will have to check the level after running it a bit as it takes a while for them to fill. Sam
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
