Re: H starting problem
Posted by oldtanker on August 21, 2011 at 07:10:09 from (66.228.255.223):
In Reply to: H starting problem posted by Wyokid on August 20, 2011 at 15:22:20:
Just cause the bowl fills with gas don't mean that the flow is fast enough to keep up.
I don't think yer going to find a plugged passage. Sounds like it's in the tank or at least before the needle and seat. Bowl is filling with gas, gas is run out of the bowl and you don't have enough fuel flow to keep up. Thats why it starts and run again in 5 min or so for another brief time. So check the flow at the carb. With a clean container disconnect the fuel line or open the bleeder on the bowl and catch that liquid gold in the clean can. Should be a steady stream of gas coming out for a couple of minutes.
Most of the time if it's the coil or condenser it will run a little longer than 5 min and require a 15 min or so cool down before running again.
Rick
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
