806 pto clutch adjustment
Posted by ChrisLSD on August 22, 2011 at 05:10:41 from (97.114.240.188):
I found out that my PTO clutch is slipping under heavy load the other day - How does one adjust that?
the forage harvester will pull the tractor down in a heavier spot, but just before a plug the PTO will slip rather thatn than pull the tractor down further.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
