Under the rotor the cam is hollow. There is supposed to be a piece of felt in there to hold lubricating oil. A couple of drops once a year is all it needs. That is what lubricates the cam movement on the distributor shaft.
The other place that needs lubrication is the advance mechanism under the breaker plate. It should be lubricated with a soft grease at the time of an engine overhaul. It would not hut to take a look at that every 5 - 10 years.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
