Re: idle speed on H
Posted by Janicholson on September 03, 2011 at 21:09:41 from (67.72.98.45):
In Reply to: Re: idle speed on H posted by c1802362 on September 03, 2011 at 18:56:00:
One on the distributor lead at the coil or distributor, the other ground. The Voltage makes no difference, unless yours is different than most. Set to 4 cyl, or 1/2 8 cyl reading.
The low idle speed should be in the area of 500 to 600 RPM. they do not have much power at idle.
They should run well though. As indicated below, tweak the two screws to get it right. Make sure the timing is correct, or it will not idle well.
The timing advance must also work! Unless it has a mag, then the idle can be a bit lumpy, and the timing be correct. They have no centrifugal advance and once started are at full advance. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
