Posted by Owen Aaland on September 06, 2011 at 13:12:29 from (216.47.32.147):
In Reply to: spark plugs for a M posted by kennell on September 06, 2011 at 05:33:35:
The Champion D16 plug was replaced by the D15Y as the recommended plug for normal use about 50 years ago. The D15Y is one heat range colder but it is an extended tip so it worked a little better. When the leaded fuels were phased out Champion changed the recommendation to D18Y for normal service but kept the D15Y for severe duty. For light duty you can use a D21 plug. That plug will help if you have an engine that burns some oil. You should not use the D21 if your tractor is going to be run for any length of time under full load like plowing. If you have trouble with fouling plugs under heavy loads you really need to address the oil/fuel problems.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
