Thereare two issues that are very important!!!!! 1} The PTO is going to run at the same overdrive, you would need to either not use it, or use a shaft tach to determine the throttle detting for 540rpm. Not much power at less then 1/2 throttle. 2} The Belly pump Liftall (if it has one) must be disconnected and not used because of that same overdriven gear set. If converted, or is a stage II tractor, it will have an engine driven Hydraulic pump on the engine in fromt of the distributor. If so no issue there, it will work correctly. (pto still wrong in OD) Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
