Re: 656 starts and stops
Posted by Janicholson on September 13, 2011 at 17:36:55 from (96.24.99.126):
In Reply to: 656 starts and stops posted by Chuck from Wisconsin on September 13, 2011 at 14:17:47:
I think Gene bradley has it. It could be a wire or connection in that circuit as well. Jump battery voltage to the solenoid directly with its normal wire off. If it runs great, follow the wire back to the switch. If it still runs poorly, the switch could be cutting out the ignition. Bypass that with a hot wire as well. Runs great, replace the switch. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
