Posted by pete 23 on September 14, 2011 at 12:54:35 from (74.32.234.149):
In Reply to: water pump posted by Smta on September 14, 2011 at 12:33:46:
It has a packing behind that nut with all the notches. It can be tightened but you will need a spanner wrench or devise some method. Problem if it is leaking a lot the bushings may be worn bad on impeller. If you grab hold of the impeller drive and can move it side to side tightening will not do much good. Also, you have grease fitting, one on impeller, on for ball bearings in hub. A shot or two of grease will often times stop a leak for a while.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
