Correct timing at idle and at full throttle no load is essential. TDC at idle, and with a light look for the last timing mark for full advance. Adjusting the carb idle screw for best idle, and low speed 450rpm. is usually good. They can make some sniffling noises. If it is 12v it needs a ballast resistor in the circuit between the ignition switch and the coil. The coil should be attached with the Plus terminal to the distributor if it is Positive ground, and - to the distributor if it is - ground. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
